1 - 20 of 31 Posts
i was looking for a filter to fit my T25 and i came across a 52mm motorcycle filter. if fits the turbo inlet perfect but i was wonderign it maybe it was too small. i posted a pic below.
It looks really restrictive. Especially since it tapers down to what looks like smaller than your inlet.
Most cone filters from Autozone and the likes come with adapter rings to fit them on smaller diameter mountings. I suggest trying to find one with a smooth transition, like a velocity stack built in. Isn't mandatory though.
If the filter fits itll be just fine.
I don't know man. Not much surface area on that filter. It won't take much to dirty up and reduce flow to the point where he sees a loss.
the geometry i was studying last week comes in handy for this
filter inlet area (.5 x 5.2cm)(.5 x 5.2cm) x 22/7 = 21.25 cm square
filter surface area 22/7 x (.5 x 5.20) x 5.5 = 44.94 cm square
Yeah, I'd pass on that one.
That thing is aout the size of one youd clamp on your vc vent. Not gonna draw much air threw a straw.....
its way bigger than a valve cover filter. its 52mm, and according to my micrometer the T25 inlet has an inner diamter of 44mm...
Whether or not it will "work" is relative. Will it let air flow through it? Yes. Will it be free flowing enough to not cause a restriction? I would say no.
Think about it this way - K&N makes a filter for the 1995 Camaro v8. That filter flows 441 cfm when new. The area of that filter is 443 cm2. 10 times the area of your filter. Your turbo requires roughly 300cfm, more or less depending on how hard you are pushing it. Giving your current filter the benefit of the doubt, and saying it flows 100 cfm, still rates it well below where you want it to be. And that is brand new.
But it's your choice. Me personally, I'd go spend $30.
A bigger filter.
Sorry, didn't see the part about you having a 3" already. Make it work.
Ya gotta get crafty son!
This
and a short section of 3" pvc pipe. Done.
1 - 20 of 31 Posts
