1 - 6 of 6 Posts
I was looking for answers for a friend that wanted to use the coil on plug system(COP) on a D16. I told him of the two main problems behind using it, the ECU being OBD2b and the provisions for the ECU to monitor the engine(cam sensor). I saw that the a2 had what looked to be mounts on the head for a dizzy, like the older D16 heads. Is this true? And if so does this mean you could use a cam sensor from the D17 on the D16? I figured he could swap in the harness from a '01 ex and just swap in the plugs he'll need to keep from the old harness. I thank he is just searching for answer's to care his momentary boredom, and I'm answering them to care mine. I don't think he'd ever does this, we both know the gains aren't worth the draw backs but would like to know if its possible....
yeah why not just throw out 300$ out the window might be more fun
... I don't think he'd ever does this, we both know the gains aren't worth the draw backs but would like to know if its possible....
2002 Civic LX-G
The D17 gets cam position data from a sensor mounted on the belt side of the engine beside the cam pulley. Not on the would be distributor side. Special timing teeth on the cam pulley required too.
aka dont do it!
1 - 6 of 6 Posts
