1 - 17 of 17 Posts
Hey guys sorry to start this thread but i am absolutely clueless and have searched alot about it and came up empty handed everytime. I got a 91 crx si and there is a big rectangular box to the left of the battery tucked down on the frame rail. It looks like a bigger injector resistor box but it has a triangular grey 3 pin connector the wires that go into the box are 2 red and 1 white. Any advice or answers would be great :) thank you.
Im in canada british columbia. Scince im a "n00b" i cant post pictures on this website but on google images if you type in "crx voltage regulator" it look identical to that but just 1 grey plug
this is the closest thing to it i could find but i know this isnt actually it. it doesnt have all these grounds on it just bolted to the subframe beside the battery with one 3 pin connector coming off it. 2 red and one white wire.it looks just like an injector resistor box off an ef but longer (more rectangular) and instead of a green 6 pin connector its grey 3 pin. I know quite a bit about hondas and i have never seen something like this before without being able to research it and find answers. is there a way i can post a picture of it i have it on my phone.
To post pics from your phone you need to down load the photobuket app or something like it. Once you have the app,upload the pic(s) you want to post on this fourm,once there uploaded copy the IMg code then paste it here.
alright thanks will do. 2jzdreamin i think ive heard on some forums that you build harnesses? i got my whole engine bay stripped down for the so famous shave and tuck look lol. in need of a harness cause mine is chewed to **** and melted. just droppin a z6 in once painting is done.
Doesn't look stock. Anything on the back of it?
I have torn every single wire out of an 88 USDM CRX SI and HF and never seen that box before.
Discussion Starter #16
I know same here torn apart harnesses from efs n then i come across this bullshit when im trying to tuck my pas side headlight harness. So ill track the wires back n see what i can find.thought i had a virgin cabin/ headlight harness but i guess not eh
So i traced them to the under dash fuse box in connectors. Not ghetto spliced. It looks factory. The white with red stripe is coming into the black plug on the back of the fuse box. And the other 2 wires are red with green stripe and red with blue stripe they go into a long connector beside the black plug at the back of the fuse box. Im really confused. It all looks factory. But it cant be.
1 - 17 of 17 Posts
