1 - 7 of 7 Posts
Meat Popsicle
91 CRX Si
Time to clean up the garage and get rid of the stuff that I never used for my build.
2.) SPAL 5.2" Puller Fan. A good fan for a water to air heat exchanger. $45 shipped
https://www.summitracing.com/parts/spu-ix-30103011
3.) CRX AC Bypass Duct. Needs new foam.
Without foam - $55 shipped
With new foam - $65 shipped
The zdyne ecu still work correctly? And do you have the software and cable to program it?
Meat Popsicle
91 CRX Si
Discussion Starter · #5 ·
I PMd you back. Yes it works perfectly and I have everything you need including the software. You may need a DB9 serial to USB adapter though if your computer doesn’t have a COM port
1 - 7 of 7 Posts
