96dx saloon
so i was pulling out my cam tonight to send to bisi and saw that my motor had roller tipped rockers. i just thought that was pretty cool.
Why did you label it f23 is it an f23 head. Cus your sig has your old setup
96dx saloon
i am currently in the middle of duing an f23 swap. i guess i will go ahead and change my sig as to no longer cause confusion. when i pulled the cam out it accidently hit the ground and now there are very slight scratches on a couple of the big lobes. do you think this will be a problem. bisi will be modifying the cam so i didnt know if it would be taken care of when he did his thing.
ryan
The H Badge is it!
91 crx
when he regrinds it, he is going to weld a thick bead of material on each lobe, and regrind it off... so im guessing the weld will fill a tiny scratch.
