1 - 20 of 23 Posts
If you are looking to restore your CRX back to OEM, there is nothing nicer than having
the correct labels on your parts to give it that 100% OEM factory look.
Here's some info I dug up, that dont sometimes show on dealer parts lookups.
Underhood Information Service & Emissions Label
w / o Calif Injection System
DX Model
1988 17277-PM5-A01
1989-91 17277-PM5-A02
HF Model
1988 17277-PM8-A00
1989-91 17277-PM8-A01
Si Model
1988 17277-PM6-A00
1989-91 17277-PM6-A01
w / Calif Injection System
DX Model
1988 17277-PM5-L01
1989-91 17277-PM9-L11
HF Model
1988 17277-PM8-L00
1989-91 17277-PM8-L01
Si Model
1988 17277-PM6-L00
1989-91 17277-PM6-L01
Fan Caution Label (Located On radiator)
w / Toyo Radiator
1988 19018-657-000
1989-91 19018-P08-000
w / Denso Radiator
19018-PK1-003
Upper Timing Cover Label (Located ontop of upper timing cover)
31117-PM5-A00
Tire Pressure Label (Located on left side inside Glove box)
DX Model
1988-89 42760-SH3-T30
1990-91 42762-SH3-A50
HF Model
1988-89 42760-SH3-T10
1990-91 42762-SH3-A40
Si Model
1988-89 42760-SH3-T50
1990-91 42762-SH3-A61
Fuel Filler door label (Unleaded Fuel Only) (Located inside Fuel door)
17669-SA0-670
Intake Manifold decal (PGM-FI)
(MULTI PORT/PGM-FI) 17113-PG7-310
(DUAL POINT/PGM-FI) 16489-PM5-A00
Fuse Label under dash
77762-SD4-000
Reserve coolant tank Label (Placed ontop of coolant tank cap)
19105-PM3-000
Airbox intake info Label (Located ontop of airbox)
1988-89 17273-PE7-661
1990-91 17273-PM5-A00
http://i107.photobucket.com/albums/m305/rob89m3/DIY/vxbfk.jpg
Fuse Box Label (Located ontop of engine bay fusebox - comes with fuse box lid only)
38250-SH3-961
Ignition Switch "Push" Label (Located on steering column cover)
53231-SB2-000
Rear model decal
75723-SH2-A21ZB - Si (red)
75723-SH2-A00ZE - HF (light grey)
Rear Grey 'HONDA' decal
75712-SH2-000ZJ
Front Hood chrome 'H' Emblem
75700-SG0-000
1991 Special edition door decal
75772-SH2-C91ZA
ministry of mayhem!
93 honda integra
awesome info, robb.
thank you.
this should be stickied.
1991 Honda CRX
Do you know if you can get new vin sticker/plates from the dealer? Mine got paint on it when the masking tape leaked and screwed it up. Also my dash one got bent when transferring it to the new dash. I assume you would need to bring registration, but can you get them still.
No clue.. sorry
1 - 20 of 23 Posts
