1 - 4 of 4 Posts
If your tranny blow's or whatever the hell you call it when a tranny fuck's up, can it ruin your motor? What's the worse thing that could happen to your tranny, would if F#$k up your motor??
i think the motor is usually fine if the tranny goes. Worse that can happen is you'll either hit the revlimiter accidentally... or if something happens to lock up the tranny then you'll damage the bearings when you jar the crank to a stop. However, your clutch will most likely slip first, unless you have a super strong clutch.
1 - 4 of 4 Posts
