1 - 13 of 13 Posts
today i went to the scrappy and found myself a d16y8, which i needed the cam shaft, rocker assembly and ecu. all was going well until i looked at the ecu code and it said p2e :S rather than p2p. i looked up and the car is automatic. the rocker assembly has ex stamped on it and the engine bay is definately stamped d16y8.
if i was to get hold of a p2p ecu am i going to get vtec? the ecu code is as follows 37820-p2e-g01-906-105870. i also thought that the 0 in g01 meant it was a manual :s so i am extremely confused
1998 Civic coupe ex
p2p is what my auto ecu was tagged as . just checked and my 5sp ecu is p2p
a81 what year is the car that may have something to do with it.
I don't know where you're getting that ECu code from. Usually it's on a label on the side of the ECU with a bar code and would simply say: 37820-P2E-A01.
Variations in the last 3 digits, A01 in my example, would tell you whether it was an auto or manual but I can't tell you what those values would be.
However, a P2E ECU runs the D16Y7 non-VTEC engine and the P2P runs the VTEC D16Y8 engine.
this is why i was so cofused, also the vtec solenoid was missing aswel :S i thought someone may have salvaged it before me. yer it said p2e-g01 which would suggest its not an auto ecu aswel :S the head code was still p2j-2 so do you think that the rockers and cam are still vtec parts and all i will require is the p2p ecu? im swapping it too my d15z6 u see :)
Maybe someone got there ahead of you and bought the P2P ecu, the yard guys put a P2E ecu hoping a bulk sale can still be made but what do I know? (call me Mr Paranoia lol ; but they happen)
Missing vtec solenoid is enough to indicate someone got there first.
possibly lol so back to the issue, is there a way of knowing whether the rocker assembly and camshaft are from the d16y8? like i said the rockers have ex stamped on them. because if this is right then i will need is a p2p correct?
also i forgot to ask, will there be a problem swapping these parts from an automatic to manual? as the headcode for the car i took from was p2j-2 which is the auto. as i said before im swapping them into my d15z6 :)
d-series Member
um isnt p2j the d16y5(hx) designation? sounds like an y5 head on a y8 block with a y7 ecu... messy
automatic stuff doesnt affect the head other than the iacv.
no the y8 is p2j according to my research, the rockers n cam is compatable with my head. i should be ok then, coz thats nothing to do with the iacv, does it?lol anybody have a spare p2p laying about?
My engine's a hybrid of:
Y5 block - P2E - same as a Y8
Y5 head - P2J - same as a Y8
jdm D15B rocker arm assy - P08 - same as Z6
Best way to find out is to check for LMAs in the head.
If you see them then it's good - you have a Y8 and the cam will definitely have to be a 20-lober LOL!
matic? manual? it doesn't matter except for the iacv like what hatchnthoughts said.
yer ive taken it all apart and cleaned it and there are LMA's,just need to checktheir tolerances. do u know anyone on here who may have a p2p ecu i can buy? or do i need the min posts for that?
1 - 13 of 13 Posts
