1 - 4 of 4 Posts
EG6
an ej8 coupe
look at the diagram in post #5 in the first link you posted. you'll basically have 1 hose coming from the compressor outlet to the MBC. then you will have another hose from the MBC that will go to your waste gate.
also with any wastegate; you can only increase boost higher than the spring rate in your wastegate, you cannot go lower unless you swap it out for a different spring rate.
EG6
i know you can adjust the springs and cant go lower then the set amount on the spring. but there is two spots for vacuum on the external wastegate.
1 - 4 of 4 Posts
