so you saying that... get the wastegate now, but dont use it on my setup right now? or at least wait till i get a bigger and better setup like on a t3/t4 turbo at least?then buy it and sit on it untill you can really use it. I've done that with plenty of parts (and cars..) and it works out.
i am guessing you have a z6 or y8 engine? and are you also running a td04-15g turbo or is that a bit bigger? how big of a hole did you drill on your manifold? and with your wastegate facing forward...is it pretty hard changing the springs to turn up the boost? thanks for the pic btw, really appreciate it at least now i am have some idea on how to do it![]()
heres mine, hopes this helps ya out
Exactly, if it's that good of a deal don't let it go if you know you can use it later, or if you can make a few bucks if you decide not to use it.so you saying that... get the wastegate now, but dont use it on my setup right now? or at least wait till i get a bigger and better setup like on a t3/t4 turbo at least?
ah i c. thanks gain man for all your responses and i will keep u guys posted on my plans. thanks.Exactly, if it's that good of a deal don't let it go if you know you can use it later, or if you can make a few bucks if you decide not to use it.
is there any other alternatives/way that i can weld my external WG, rather than the one in the pic with the y8 engine? thanks.that one on the picture is Y8 block.
also, last time that same guy said that his WG keeps 11psi steady up to the read line
thanks man. i will keep u guys posted, on how it went. thanks.yes.
You can weld it up front in the middle, where the screw hole is.
You can weld it of the left runner.
You can weld it on the internal WG port.
You can make a spacer between the manifold and the turbo, and weld the WG on that spacer
