1 - 20 of 29 Posts
External Wastegate with td04 turbo...is this possible? *UPDATED*
Hey guys,
As most of you know I am running a td04-15g turbo on my b7, since my buddy is parting out his turbo setup. I am thinking to get his external wastegate. Since, my turbo has an internal wastegate. Will his tial 38mm wastegate work for my turbo? Is this gonna be an expensive conversion? Or is this just a straight bolt on to my turbo? Thanks gain.
· Lifetime Awesome Member
'89 CRX HF
i have greddy cast manifold, will the tial wastegate still work? and is this gonna be pretty hard to do? thanks guys, keep the response coming.
you are going to need to drill a 35mm hole in it and then weld a WG flange to the manifold itself. not the best method, but it can be done
You can do it, but the internal gate i9s fine for how small of a turbo you have.
Discussion Starter · #8 ·
yeah probably my internal wastegate is sufficient enough for my turbo right now. but an external wastegate is easier to turn up the boost by chaging springs and i wont have much boost spike with it.
Discussion Starter · #9 ·
well my buddy is willing to throw in the d-series manifold with a T3 flange(from his old turbo) and the tial wastegate flange, so i guess that should solve my problem. just wondering when we i put in my buddies new manifold...do i still need to get this welded? or is this just a straight bolt on to my setup?
you can change the boost by using a manual boost controller. With such a small turbo, its probably easier and cheaper this way. heres one from blaast performance for 20 bucks
http://www.blaastperformance.com/index.php?p=product102
You would still need to get the internal gate welded shut, but I don't think the 15G uses a T3 flange. So you would need a differant turbo, but that's not always a bad thing.
or you can weld your external WG with a separate pipe on the internal WG port, and keep your stock GReddy manifold.
the 15G uses T25 flange
Discussion Starter · #13 ·
well my friend is willing to throw me a good deal if i also get his turbo with manifold and the wastegate. specs of his turbo is (T3/T4oE 50 Trim .48 A/R hotside) compared to my tdo4-15g. roughly what the max boost/power can the t3/t4 put out more? and if you guys had a choice...would you go for the t3/t4 or my tdo4? oh yeah my engine is a b7. thanks guys, now I am in a real dilemma.
That's a lot of work for no gain, you'll run out of turbo before you need an external gate on a 15G.
I'd go with the T3/T04E over the 15G. I'd also get a D16 to build while I'm at it. You shoulden't don't more than 10PSI on the 50 trim and your at the edge of what your motor can handle.
Discussion Starter · #15 ·
when you said i need to drill a 35mm hole...you mean on my current greddy manifold right? well just confirming. you think i can weld the External WG flange somewhere in the middle of my manifold? or is there a better place on my manifold to put the wastegate? thanks.
You can, but to say it agian, there's no point if your useing a 15G. If you pick up that T3/T4 and manifold then worry about an external gate.
Discussion Starter · #17 ·
i see your point there man..is just i am getting such a good deal from my friend for the tial wastegaste, i just cant pass it up thats why, since he really needs the money, cause he is moving. so can i still get the tial welded on my greddy manifold then?
then buy it and sit on it untill you can really use it. I've done that with plenty of parts (and cars..) and it works out.
1 - 20 of 29 Posts
