Hello D series car nutz, we are very happy to offer our products here.
All of our products and hand made and hand crafted and made out of steel. Made in the USA! In house! We take great pride in our work and it shows in the quality of the parts. We like to think our stuff is high end, from the thought and enginnering to making them and the final result. All of our products are built strong and built too last. All of our products come with a semi gloss black powder coating. Other colors available but may cost a little more. Check with us. Lastly, our prices are very reasonable. Please Email or Call us or PM or AIM us with any questions or wanting to purchase. Please check out our site for detailed pictures of our products and our happy customers. Thanks-John
Website: www.ExplicitSpeedPerformance.net
Email: [email protected]
AIM: ExplicitSpeed360
Phone: 1-360-866-8530 John or Dan Gordon
Explicit Speed Performance Traction Bar Systems
They are built strong and built to last! The World's Fastest Prelude is running our Traction Bar System and we helped him get there! A Traction Bar System is not only for race cars it's also a great investment for your daily driver. We use square tubing over round, from our tests and research we have found that square tends to be more stronger and have less bow in it when stress is pushed upon it, thus making the product more effiecient. They are made out of 1 1/2" x .170" square tubing and 1/4" thick plate. Everything is mild steel. It comes complete with swaged polished aluminum radius/tie rods and chrome-moly heim joints. We use top of the line products, thick diameter radius rods, so they wont break or bend and high quality heim joints that will handle an unbelievable static load. As well as Grade 8 and 10.9 fasteners. We have Traction Bar Systems for the following chassis, EF/DA/EG/EK/DC/BB/CB7. Our Traction Bar Systems are tucked up nicely so ground clearance is not a concerned. On the EF chassis the Traction Bar System is 1/4" below the radiator tabs. Traction Bar System replaces stock front cross member.
EF 88-91 Civic/Crx Hatch/Crx/Sedan Traction Bar System D/B/F/H/K series compatible
$350 shipped US...
EG 92-95 Civic/EK 96-00 Civic Hatch/Coupe/Sedan Traction Bar System D/B/F/H/K series compatible
$350 shipped US...
Explicit Speed Performance 2/3/4 Point Custom Steel Strut Bars
Toss out your cheap aluminum strut bars! Steel is 2-3 times stronger then aluminum so imagine how much more effiecient a Solid Steel Strut Bar will be to keep the towers in there position and eliminate shock tower flex. On top of that we use square tubing which we feel is a lot stronger even more efficient. Our Strut Bars have no joints to cause weak points. Just solid mounting points. They have speed holes in them and just look sweet. We make the 2/3/4 pt Strut Bars for almost all chassis EF/EG/EK/DC etc...Clears all swaps...D/B/F/H and possibly K series motors...Also clears cars with swaped Integra brake boosters and MC.
3 Point Front Upper Strut Bar $189 shipped US
2 Point Front Upper Strut Bar $139 shipped US
4 Point Rear Upper Strut Bar $209 shipped US
2 Point Rear Upper Strut Bar $119 shipped US
2 Point Rear Lower Strut Bar $99 shipped US
Explicit Speed Performance D series Motor Mount Kits
Using certain insert adders to the OEM mounts is like putting a bandaid on it. Your still using it with the old 10-15 year old britle OEM middle rubber insert and the cheap britle metal mount. Your better off geting a complete replacement mount that will be a lot stronger and better made as well as using a complete polyurethane mount. Our Motor Mount Kits include a set of 3, driver side, passenger side, and rear. The front mount isn't needed with our mounts in my h22 crx I can put all of my weight on the engine to try and budge it and no budgy! Imagine how that will perform on the street with the potential of getting more power to the ground, which is the name of the game. Better hadeling, and corenering and ET's. Add this along with our traction bar system and your ready to go! Ask for our Packaged Deal! This isn't only for high horsepowered cars great for the daily driver as well! They are made out of steel and are built strong to take the abuse! We use 70A polyurethane inserts. They are easy to replace if you later want a different grade. Fitment is Great. We have had very good feedback. Choice of Red or Black poly colors.
EF 88-91 Civic/Crx/Sedan 5 spd D series Motor Mount Kit with use of 88-00 D series engines
$235 shipped US
EG 92-95 Civic Coupe/Hatch/Sedan 5 spd D series Motor Mount Kit...Contact US for information!!!
$350 shipped US...
$350 shipped US...
$235 shipped US
