i want some input form some people that have used there cams. im looking at the stage 3 cam for my y8 build and wanted to know how well it will work with boost. an is this to much cam for a dd.
peterbilt
i would recomend a stage 2 for a dd depending on what your setup is
Administrator
93 cx hatch
im running their sage 3 cam in my zc vtec with boost
i ran it na for a while also with no problems... it really helps in the higher rpms and sounds sick at idle
it is by no means a cam that shouldnt be bought just because its for your dd...
well im going to use the kms stg.2 valve train package so ill have springs an retainers an shit so ill have the proper set up to run a nasty cam. i have a stage 2 crower n/a cam now an i ran it n/a, an boosted. i guess the best question to ask is it worth changing to a turbo cam. i know the over lap is slightly diffrent but will i pick up much more hp?
yea im kinda running out of info i just may have to
96 hatch SIR
Cmon peps shine in with more info cause I need it also to squeez some more hp out of the already built block.
