Im gonna be putting the turbo on my car soon and was wondering if my current exhaust would be fine. Its a 60mm Invidia N1 Catback for the CRX. The turbo i will be using is a t3t4 57 trim .63, I plan to run a 2.5" dp to a 2.5" test pipe to the invidia catback. Im only looking for 200-230whp. So will this exhaust work? Also with kind of spool time would i be looking at?
Honda
should be good, your goal will be easier to acheive with larger dp and exhaust, but what your running should suffice.
Black Dynamite
1991 HONDA Civic
You should be good. I'm running the same thing
'95 Civic dx
That should be fine for your goals :TU:
x2, im running a 2.25" (lil bit smaller than 60mm) magnaflow cat back with a test pipe, and my t3 spools just fine, full boost by 3500 rpm... only thing that restricted it was the cat when i used to have it on my car
