Its your exhaust leak more than likely. If it still sounds like its leaking, you need to fix it.
Wideband oxygen sensors sense "oxygen", a leaking exhaust upstream from the wideband sensor will draw fresh air into the exhaust stream, and skew your AFR readings.
If the car was fine till the exhaust started leaking, and still feels fine, then the tune is probably still fine, and the exhaust leak is drawing in pre-sensor oxygen giving you a false lean indication.
Find the leak, and fix.
