1 - 9 of 9 Posts
P
Is it possible to put an ex gauge with tach on the 98 dx
THANKS A LOT GUYS
E
yup I did it and so did my friend. Hardest part is taking off your stock cluster, and that aint hard at all.
P
so the tach has a plug for it...when i open it up there is gonna be an open plug for the tach to attach too..?
Well sort of. All honda's are wired for a tach. When you open it up, there are three or four wiring harness that you have to unplug from your DX cluster, and then plug into you EX cluster into the exact same plugs. Then it'll work!
E
greddytunedhatch said:
those 5 screws are a bitch, aren't they?
lol...one of the screws was stripped or something. IT WOULD NOT COME OUT..i forgot how we managed to get it out. haha
gauge
if you want to retain the current milage on the speedo (for license renewal) take a look in diy at my post on changing out the speedo in the cluster. it might work for your model as well.
1 - 9 of 9 Posts
