Moudy said:
How to plot points on a compressor map:
Calculate airflow for the X axis: measured in lb/min, airflow = (HP target) x (air/fuel ratio) x (BSFC/60) where BSFC is lbs fuel / (hp x hr) If you don’t have access to BSFC data, you can plug in an estimated value between .50-.60.
Calculate volumetric efficiency = (actual CFM / theoretical CFM) x 100 where theoretical CFM = (RPM x CID) / 3456 and actual CFM = 90%, a good average number if you don’t have access to measuring this. Multiply by .0610237 to convert cubic centimeter displacement into cubic inches.
Calculate manifold absolute pressure: map = [(airflow) x (639.6) x (460 + intake temperature)] / (VE) x (RPM/2) x (CID) Upwards of 100 degrees F is a good estimate for intercooled intake temps if you don’t have access to measuring this. Plan on adding about 1psi to take into account pressure drops related to the intake and/or intercooler.
Calculate pressure ratio for the Y axis = (14.7 + map) / 14.7 If you’re at sea level, 14.7psi will work. As elevation varies, this figure will need to be adjusted.
Note: Don’t worry about the constants like 3456, 60 or 639.6, they’re simply there to tidy things up and convert units.
VE = volumetric efficiency
BSFC = brake specific fuel consumption
HP = projected flywheel horsepower
CFM = cubic feet per minute
CID = cubic inch displacement
Other useful calculations:
Trim = (minor/major)squared x 100
Trim describes the relationship the minor diameter and major diameter of a compressor or turbine wheel shares with each another. The inducer, or minor end when referring to compressor wheels, is where the air enters. Air exits through the exducer portion.
full post: here
good info. thanks
