1 - 20 of 24 Posts
www.ExplicitSpeedPerformance.net
Explicit Speed Performance
Email: [email protected]
AIM: ExplicitSpeed360
Phone: 1-360-866-8530 Monday-Saturday 10am-5pm
Ask for John
We, Explicit Speed Performance also fabricate custom strut bars for the Honda/Acura applications below. Our pieces are stronger than any other products out there. They will also be at an affordable price. They will help your car both on and off the track. Unibody cars have shock tower flex both in the front and rear. These strut bars will stiffen up your front and rear and will add strength to your chassis. They offer better handling and will help eliminate shock tower flex. All of our products are hand made and are high end quality. They are made from flat 3/16" and square 1" x .095" mild steel. They come with with a semi gloss black powder coated finish. For additional cost we have 150 other powder coating colors to choose from. Inquire for pricing on additonal color cost.
Toss out your flimsy aluminum strut bars (Ebay) with joints. Having a joint causes a weak point. Solid Strut Bars are much more functionable. Our Steel bars are 2-3 times stronger then aluminum bars which means our bars are much more functionable. Insructions are included. 2/3 Point Front Upper Strut Bars will clear all D/B/H/F/K swaps as well as Integra Brake Booster and MC. You can also keep your fuse box in the stock location. The emissions box in the back needs to relocated on the 3 Point Front Upper Strut Bar only. 2/4 Point Rear Upper Strut Bars require the plastic to be notched, function first! Simply cut the plastic with a heat burning tool and use some weather stripping to make a clean install. 4 Point Rear Upper Strut Bar can be used with the space saver tire but not a Full Size Spare. It also uses 1 bolt on each side of the frame on the back 2 points to create the best function 4 Point. Installing the 4 Point Rear Upper Strut Bar is simple as bolting it up marking the holes, unbolt it, drilling holes into chassis for the rear 2 pt's and bolting it up with our supplied hardware.
EF 88-91 Civic/Crx 2 Point Front Upper Strut Bar
$129 shipped US <----- Special D-series.org Pricing
EF 88-91 Civic/Crx 3 Point Front Upper Strut Bar
$179 shipped US <----- Special D-series.org Pricing
EF 88-91 Civic/Crx 2 Point Rear Upper Strut Bar
$119 shipped US <------- Special D-series.org Pricing
Nice thick quality SS bead welds
Other Chassis Work:
EF 88-91 Civic/Crx 4 Point Rear Upper Strut Bar
$209 shipped US <----- Special D-series.org Pricing
EF 88-91 Civic/Crx 2 Point Rear Lower Strut Bar
$89 shipped US <----- Special D-series.org Pricing
Yup, these strut bars are blingin guys... get compliments every time I pop the hood :) 150 powder coating colors to choose from!!! Near chrome comes out billet aluminum look, we have a pearlescent bronze that is like a pearl gunmetal... list goes on... :)
Hi hater!
I have been thinking about stut bars and totally forgot about you guys. When I get some more cash you will be getting a call about some of these things love the track bar great quality work these guys do support them if you can. Thanks for making stuff for the CRX as well.
Thanks for the post! much appreciated. Remember as always we offer Packaged Deal Discounts with 2 or more bars purchased at once. Hit me up I am always willing to hear what you have to work with.
If you have ever seen our strut bars there pure blingin and sexC! I will guarantee they are stronger and more functional then any strut bar out there on the market!
can you get the upper 2 point w/o the studs for speakers? i want to keep my interior
Discussion Starter #17 (Edited)
Yes I can if you want on our 2 pt rear upper strut bars put your 6x9" boxes mounted to the bar like I did, I can weld on 2 studs on each side for no extra cost or 1 stud on the rear side for sub box's. :) -John
1 - 20 of 24 Posts
