1 - 6 of 6 Posts
Hello. I have a '96 Del sol with D16y8 which is turbocharged. I would like to add equal length axles. My block has provision mounts for half shaft but I am not sure:
1. Which half shaft I need
2. Which driver side axle
Any ideas? I live in Europe and we have a small D powered SUV (the HRV) but I am not sure the half shaft from this model fits.
\/Your Mom Was Here\/
Vibe GT
The Y8 does NOT provision's for the half shaft. The A6 did and Z6 had to holes but needed to be tapped. You would need a hard to find Hush22 adapter to make it work.
1996 Civic Type DX
Non-US markets have some really strange models, its possible his block has provisions. That said you can't just run a half shaft, you need the correct differential. You'll either need an OEM DOHC ZC open diff or an MFactory DOHC ZC helical LSD. You will use the DOHC ZC halfshaft. Either of the diffs can be ordered from me if you can't source them locally.
Discussion Starter · #4 ·
Thank you for the replies guys. I am pretty sure my block has provisions. But apart from the LSD (Unfortunately, I already have a D series hydro Mfactory LSD), what axles will I need?
1 - 6 of 6 Posts
