1 - 3 of 3 Posts
my motor spin a bearing acl bearing I had a oil sandwitch plate to the oil filter feed line atleast some filtered to my feed to the turbo. however my turbonetics turbo has a filter screen on the turbo from turbonetics. btw its a journal bearing turbo. I cleaned removed all debris had very little but cleaned it good. is this turbo ok to use?
I also have another motor ready to be run should I remove the drain when crnking the engine building pressure and see if I can fluid it that way. or not necessary? was thinking using a blow gun to just blow it on the bench also?
is there any advice in using the turbo?
should be ok if it was all filtered
See above...
Yeah, it should be fine. My Bullseye turbo was fine after I spun my #4 rod bearing in my Z6. The only thing you might want to check in addition to what you've mentioned, is the vtec noid screen. Mine was packed with shavings afterwards.
1 - 3 of 3 Posts
