ok, so i put ZC pistons in with standard rod bearings. now im converting back to stock pistons and rods, but i dont know which piston goes to which cylinder as i think it matters when choosing rod bearing? this time round im going to get the proper color code cause im boosting... so how do i know which piston goes to which cylinder, or would it matter?
as long as the arrow on the piston is pointed toward the timing belt area you are fine.
and for rod bearings, there is a stamp on each rod match that number with the numbers on the crank to get your color. make sure you know what color you want before you go to the dealer. when i got mine the parts manager didnt even know how to order the bearings.
hahaha. the wierd thing tho is the zc rods i had have all 6 on the side of the rod? so does that mean all the bearings were the same for that motor? or do i look at the rod end cap for the number?
