P
okay i have a 94 civic dx sohc it hitting close to 200k miles so i'm looking for a decent priced engine but while looking i found an add in knoxville there is a place that sells japaneese enging rebiuld kits has anyone ever gone that route? will it save my engine it is only around $300.00 if anyone nows then please reply thanks
P
not sure i still have the add but have to find it will 185 really fix my engine ? cuz it smokes and ticks the valves are going bad..but i t stought as hell still will smoke the tires in at least 3 gears and stilkl has plenty power
W
you might need to change piston rings head gasket. you should do a compression test to find out why its smoking.leakdown test if compression goes bad and then you will kno what you need to change to make the engine run right.
ttt
guest said:
What does it included?? Knoxville, what? What's the company's name? You can get acl bearings for $100 and a complete engine gasket kit from summit for like $85.
Do you know what is included in the kit?
