1 - 3 of 3 Posts
Got a d16z6 swapped in my 90 civic wagon and it spun a bearing after a couple minutes of running. It will need a new rod/ bearing and ground down. My old engine was a d15b2. Could I make some hybrid type engine just to get it going? The b2 got pulled due to a cracked head. Could I just use the b2 short block with all the z6 stuff bolted on it? Or can I put the b2 crank/rods/pistons in the z6 block? Any other thing i could do? Id rather not use the b2 block as it had 256k miles(z6 is at 160k) and has some pretty bad ring ridge going on. thanks
Discussion Starter · #2 ·
After more looking, the z6 is definitely not a 160k engine as seller described, once again, i got ripped off. Guess ill just have to buy a new short block. Going to find one at the junkyard cause then at least i can return it when it turns out to be total crap. Thrown 2k+ at a 300$ car and have ended up with a 400$ car
95 Civic DX
It will be worth it in the end. Just go with your idea of getting a engine from a local Junk Yard with a start up warranty.
1 - 3 of 3 Posts
