1 - 6 of 6 Posts
1990 CRX DX
well this is what i have found from them , you engine doesnt move as much at High RPM they keep a little bit more torque, but they have side effects , they make your vibrate pretty bad, i wouldnt use them unless it was just a race car or a high Hp engine. what kinda mods you got what engine ?
The main thing they help with is wheel hop when launching. They dont make your car vibrate that bad. I'd recomend them.
R2.....Zap Balls
94 Ex coupe
:stupid: Def a good investment imo. I noticed a dif with mine being a little easier to shift because the motor isn't moving as much when accelerating. The vibrations you get afterwards are def worth the benefits from installing them :TU:
my car
I use them but it's mainly to reduce the powertrain movement under hard shifting.
If you don't have a high hp/high torque set up a full set of hasport mounts may be overkill for you and a waste of money.
getting mount insterts may be sufficient for you. Energy suspension makes them, they are fairly easy to install and you can definatly feel a difference in shifting.
basicly they are urethane inserts for your rear mount and dampner mounts
1 - 6 of 6 Posts
