1 - 10 of 10 Posts
So i wish I had the money for hondata but i dont im going to boost a stock d15b vtec on like 6lbs or something ide be happy with 200hp... My qusetion is would i be able to get an ecu that someone is selling that has been tuned for something else and run with that for example here is one that someone is selling
Obd 1 ecu p28 with conversion harness
Ecu has turbo set up chip in it all tunned for b20 vtec at 10 psi
Can be removed or re tunned
150$
How much different is a b20 tune goong to be from a d series ?
b20 at 10psi with e85? 91? 101?
10 psi with a t28? t66? gt2862r?
intercooled? nitrous? water injection? methanol?
450 injectors? 550? 1000?
28* timing? 16*? 10*?
30psi fuel pressure? 50? 80?
10:1 a/fr? 17:1? 14:1?
missing the point. it was "tuned" to the b20 with whatever it had on it.
Reactions: Nasty_Canasta
Sloppy Jalopy
don't expect any of the "tuned" chips to keep it together ...
usually when an engine gets tuned the , a/f timing adv ...and others
it should probably include your actual engine your going to use you know like the one in your car..but not always...
if I could just get my hands on one of those 400hp tunes ,man my car would be fast or slick what ever the hep cats say.
not being a dick here ...or am I
Meat Popsicle
91 CRX Si
No.
You can buy it and re-tune it for your engine/application but there’s no way that would work for your engine as-is.
'93 / '95 Del Sol Si - '95 DX Coupe - '00 Accord EX F23 Manual
You can run it...
But then Dom and The Mad Scientist will have to rip apart the block and replace the piston rings you fried.
1 - 10 of 10 Posts
