1 - 6 of 6 Posts
Its better if you go to the bin depot at pgmfi.org and make your own basemap from scratch.
I hate using other peoples basemaps. They just cause problems. Every setup is different, so make your own from scratch with the proper settings and plugins for your setup and your car will run better.
Formally D_Tuned
97 civic HX
Other peoples bin files should only be used to analyze and learn from not be used as a quick and free tune. The hondata software has quite a few basemaps that you can import the tables from onto other basecode. If using crome remember that in most cases you will need to start with p30 basecode.
1 - 6 of 6 Posts
