1 - 20 of 20 Posts
Z
what is the simplest and most basic setup that can be used ? could it just be done with some 450'cc injectors and a riseing rate FPR ?? or is it more complicated then that ?? what about using an safc with an FPR and 450's ??
im on a really tight budget and i need the cheapest but yet best form of engine management....now i know there is no such thing as cheap and best but i think u all understand what im trying to say.......
Z
free ???
I dont know to much about attaining free uberdata....if some one would like to help me out or even offer a service id appreciate it greatly.....i need something that will be able to run my mk3 CT26 at roughly 16psi.....if it matters any im OBD-1....
:IHI: http://www.pgmfi.org :IHI:
go through the wiki library... it should give you a good head start on the way to tuning =)
the MAD scientist
hmmm so it's a toyota? Then uberdata will not work.
Z
sorry for the confusion......the turbo is off an mk3 supra.......i have a 92 civic hatch dx with an a6 in it that i plan on boosting...
More confusion - you have a 92 (OBD1) car, with an A6(OBD0) engine?
Then which ecu are you running?
TurboEdit = OBD0
UberData = OBD1
Chipping aside...you would run a rising rate (FPR) with your stock injectors (240cc), to make them flow much more than they were designed to, to satisfy fuel requirements at boost levels.
If you are using 450s, then you do not need an FPR, as the 450s already flow enough at boost levels. What you do need, is to manage the 450s both at boost and at non-boost levels, because at non-boost levels, they will be very rich. An SAFC or VAFC is needed for this.
Although it is a bit more complicated, you'll be happier if you go with a chipping type of solution. You get the fuel management you need for 450s, and timing management as well, in addition to a lot of other stuff.
Craig
Z
its even more complicated then you think......im using from the fire wall back an obd-1 harness with obd-1 ecu....firewall forward is an obd-2 harness...a6 block and head with y8 intake mani with obd-2 sensors and an obd-2 dizzy....so im not sure what you want to call that mess but its running of an obd-1 ecu......
from what ive gathered ill need and obd-1 chip with either chrome or uberdata....and an afc of sorts on top of that to run the 450's when out of boost.......is there any way around this ?? how much can my 240's flow ?? hp wise ?
the MAD scientist
with a chipped ecu you do not need an AFC. The fuel maps are scaled to run the 450cc injectors normally out of boost.
Z
anyone on here have a chip i could purchase that would suit my setup ?? im really in need of a decent chip....
Z
thanks for the link....i havent found a tune that would suite me ....the closest thing is a 300whp tune for a b18b would this work ?? the setups seem fairly similiar besides it being a DOHC and me being SOHC
Z
16psi wont blow my shit up if its properly tuned.......im pretty sure u know that already.......sure it wont last that long maybe 6-12 months tops at those sort of levels......but thats all i need it for a decent 250whp tune
now can anyone offer there services in chipping ?? and do i need to have my ecu socketed to accept these chips ??
W
/\ :bravo: read more man your in for a rude awakening if you think an engine will last that long on a tune not even for your car. pgmfi.org like was posted earlier and read. after you read... read more. lol ---seriously do it.
The H Badge is it!
91 crx
this guy speaks the truth
theres 2 things that help YOU tune your own car... research and experience.. and u cant get experience without researching first.
the MAD scientist
yeah that and a wideband
W
Discussion Starter #18
/\ i saw gonna say that but the other two pretty much cover it.
D-Series Post Be-itch... gimme gimme gimme
The thing is, the only way you can have a good tune is if you know what you are doing.... sure, a dyno tune is great, but what about part throttle tuning?? Out-of-boost tuning?? Those things AREN'T done on the dyno (unless you want to spend a grip). So no, your setup won't run more than a few weeks if you aren't sure of what you are doing before you go into it...
1 - 20 of 20 Posts
