1 - 2 of 2 Posts
Hey Hondata,
Currently have a built D16 9:0 CR Turbo.Walboro 450, Bosch 1600cc injectors, AEM fpr set at factory fuel pressure, oem fuel lines and flex fuel setup.
Once the engine is completely warm and heat soaked (driven around for 10mins etc). I can easily get the car to idle on around 24degrees of timing, and 1.3ms from the injectors at around 12:5 - 13:0. Around 1000 rpm nice and smooth.
However just after cold start - once the engine has gone through the water temp compensation up to 80 degrees etc. The engine will constantly hunt, idle very lean and rough. Anything else i could look at to help achieve a smooth start up etc.
Ignition Dwell, air temp compensations etc
Cheers
Lyle
Discussion Starter · #2 ·
i just did a cold start log however the size is too big for me to upload here. i did notice at idle the car behaves better with more timing (already dialled in from a cold start compensation). i.e. - over 30 degrees.
any pros / cons to more / less timing at idle? and are there any limits to what is consider not safe?
Cheers :)
1 - 2 of 2 Posts
