1 - 7 of 7 Posts
im almost done gathering all the parts needed to swap my b18b1 non vtec in my 1989 std. hatch.
im planning on useing a harness from a 92-95 dx civic, i mean the WHOLE HARNESS, the one that goes thru the firewall too.
my ? is, will a 92-95 dx engine harness work on a b18b1?
thanks,
-jack
It will be much easier to just do a DPFI to MPFI swap and go. Then if you want you can convert to OBD-1 with a conversion harness and be done, but you don't have do.
okay, if i did that, the sensors on the b18b1 wouldnt clip into the harness from the d15b1...
will the clips from a 92-95 dx engine harness fit the b18b1 sensors? that all i need to know
Depends if you have an OBD-1 or OBD-2 B18B. Some of the connectors are different between the 2.
If it's OBD-1 then just carve up the EG harness for the plugs you need.
that harness should work with the b18 the only think you might have to modify would be part of the harness that will plug into the b18 ecu
1 - 7 of 7 Posts
