1 - 9 of 9 Posts
Title is pretty much the question, anybody ever have to swap an engine craddle in a 7th gen yet? I need to change one, found one out of an auto car, mine is a manual. I called the dealer, said they list 2 different part numbers, but they couldn't tell me why. Thanks in advance.
If you are asking about the subframe:
Then they have different part numbers and prices:
4ATKA 50200-S5A-A84 $496.35 (2001)
4ATKA 50200-S5A-A72 $342.64 (2004)
5MTKA 50200-S5A-A04 $519.87
01-03 rear engine mount is different from AT to MT
that maybe help in something
Yes, that is what I'm referring to. I bought an 03 manual coupe with some front end damage, the cradle is damaged and I need to find a new one. I found an 04 auto coupe that has been hit in the rear, I'm contemplating buying it for parts. If the mount is the only difference, I can most likely re-weld it in the proper location. I was affraid there would be a major difference that might cause interference with the block or trans case.
no the only difference in the subframes between auto and manual is the front motor mount is 3 inches to the left on the manual. the back mount is the same for all years 01-05. and you can buy an auto subframe and move the front motor mount, infact i have one im selling. send me a pm if youre interested.
Well I'm going to go for it, I'm buying this wrecked 04 that an auto, and I'll just move the mount. Thanks for the information. Maybe I'll snap some photos and post when I do it here in a week or 2.
Well I need to get airbags for the car too, and this one has good ones that match. Also need a door panel, so that's about $700 worth of stuff. Figure I can either sell or use the D17A2 that's in it, also has alloys I can sell. Might use the 04 sheetmetal and "convert" mine to an 04/05 style front end. Figure also if I can sell the other parts off the car, then scrap the shell I'll be ahead of the game.
ha the mout still bolts in the motor did in on mine like 2 years ago
1 - 9 of 9 Posts
