1 - 3 of 3 Posts
Couple questions.
Is a D16A6 from an EX able to swap into a 1995 DX?
Does anyone know where to find the axle lengths for both cars?
1. Yes
While axle length matters, another important question is: will the spindle on the axle fit both the transmission and the wheel hub? I can't help you there, as I don't know the lengths right off, nor the spindle diameters.
I believe the axles will fit, but someone else here could tell you better than I.
93 Legend L Coupe.
Doesn't matter about the axles, as you have to use a hydraulic transmission, anyway. You will likely need to figure out the right side engine mount bracket. I don't think that you can use the one on the A6. You may need the one from the original D15.
1 - 3 of 3 Posts
