1 - 12 of 12 Posts
Lifetime Awesome Member
Discussion Starter #1 (Edited by Moderator)
http://www.d-series.org/forums/engine-building/139561-3-wire-2-wire-iacv-conversion.html
http://www.d-series.org/forums/engine-building/141308-advanced-tech-what-makes-torque-why-do-i-care.html
http://www.d-series.org/forums/engine-building/2957-d-series-org-diy-itb-thread.html
http://www.d-series.org/forums/engine-building/100139-diy-main-bearings-rod-bearings.html
http://www.d-series.org/forums/engine-building/111485-how-really-torque-arp-head-studs-straight-arp.html
http://www.d-series.org/forums/engine-building/196698-z6-y8-between-arp-stud.html
http://www.d-series.org/forums/engine-building/87515-questions-answered-about-s2000-oil-filter.html
http://www.d-series.org/forums/engine-building/23877-d-series-carbs.html
http://www.d-series.org/forums/engine-building/22640-sohc-non-vtec-cam-specs.html
http://www.d-series.org/forums/engine-building/88387-deglazing-vs-honing.html
http://www.d-series.org/forums/engine-building/89520-found-d-series-specs.html
http://www.d-series.org/forums/engine-building/103669-auto-math-101-a.html
http://www.d-series.org/forums/engine-building/41363-y8-cam-w-z6-sprocket-z6-cam-w-y8-sprocket.html
http://www.d-series.org/forums/engine-building/45024-swapping-y8-intake-manifold-onto-y7.html
http://www.d-series.org/forums/engine-building/14790-ignition-timing-cam-gear-timing-timing-belt.html
http://www.d-series.org/forums/engine-building/21761-building-powerful-street-na-d16y8-z6.html
http://www.d-series.org/forums/engine-building/27126-d-series-org-engine-building-tech.html
The Definitive D15B7 / A6 / ZC Cam Post Answers all of your D15 and A6 cam questions.
http://www.d-series.org/forums/engine-building/153797-d16a6-head-newer-d16z6-d16y7-d16y8-block.html
D17 stroker threads and how tos:
http://www.d-series.org/forums/showcase/137595-danz-d17-n-build.html danz build thread, long winded but details everything needed.
http://www.d-series.org/forums/engine-building/122973-d17-stroker-qs.html short and to the point. the most cost effective way to stroke that D.
http://www.d-series.org/forums/engine-building/150897-how-stroke-your-d16.html more information and alternative ways to stroke the D
Engine break in discussions:
http://www.d-series.org/forums/serious-discussion-debate/153076-engine-break.html
Awesome . Very useful sticky
Thanks for doing this to help us noobs in the Honda world. Many sites have members who ruthlessly attack noobs for not being on their level of knowledge.
CHECKING VALVE OVERLAP WITHOUT DEGREE WHEEL OR DIAL INDICATOR
When installing a camshaft, or when an occasion arises where it is necessary to make a check on valve timing and no appropriate instruments are available, the recommended Isky procedure is as follows:
Insert the camshaft and mesh the timing gears on the stock marks. Do not as yet install the timing gear cover.
Adjust the valve lash of the intake and exhaust valves of the No. 1 cylinder.
Using a long wrench or lever, turn the engine over in the normal running direction. Use enough leverage to get an even, steady movement instead of a jerky motion. Rotate until the intake and exhaust valves of No. 1 cylinder are in the overlap position (both valves opened slightly). Stop exactly on T.D.C., which is marked on the harmonic damper.
Now loosen and back off the rocker arm adjusting screws until the intake and exhaust valves are just barely closed. Lock the adjustment screws so that the intake and exhaust valves are at exactly zero clearance.
Now turn the engine over exactly one revolution of the crankshaft to T.D.C. on the harmonic damper. You are now at T.D.C. on the compression or firing stroke.
Take Notice! Now there is a large space between the rockers and valve stem tips. The space indicates the actual amount the valves were open at T.D.C. of the overlap period (less valve lash, of course).
We will measure this gap space by probing with common feeler gauges of various thicknesses combined until we determine the gap space. After computing the gap, record the figures for both intake and exhaust in your notebook. If the amount of gap on intake and exhaust is exactly the same, you have a perfect split overlap.
Here is the best link on the subject. Covers all angles.
ISKY Racing Cams - Do It Right. Race with the Legend. Camshafts, Connecting Rods, Valve Springs, Lifters
1 - 12 of 12 Posts
