I have a D16Y8 and I got eagle rods ,high comp arias pistons ,aerospeed sprocket,ZC cam ..I have been researching and I read in this forum that if a I use ZC ca i have to retard the timing is that true..I will like to know because then I will have problems with the timing been correct I can have the valves damaged or the engine.
