1 - 4 of 4 Posts
do you have a DOHC??????
Then why would you ask if they fit????????
If they made two different part numbers, there must be a reason............
Like they are different!
9
save your $$ get a used mount (or use yours but let it set for at least 48 hours)
& fill it in with blue high temp gasket stuff
I had the energy inserts and hated them , I blue goo'd
all my mounts (fill in the between rubber) and they work better &
dont viberate your teeth out @ idle.
It took 2 tubes to do them all (4) and cost 12$
Take cardboard cut a hole for the sleve that the
bolt goes though to sit in so it's flat,
then I laid it flat on wax paper with the sleve in the hole and filled
in the space between the center and outer of the mount (in the rubber)
I poked it with a pin to make sure there were no air bubbles in it.
Let that sit for 48 hours & the remove the wax paper..bolt in and I
did each one over 4 weekends
...and gave the energey mounts to some one else
Hope this helps
sorry just had to ask
1 - 4 of 4 Posts
