1 - 1 of 1 Posts
Well I finished my GReddy 15G Kit install on my D16Y7 with EX 240cc injectors.
(pics for those who care)
http://img156.imageshack.us/img156/7834/0724091440.jpg
http://img268.imageshack.us/img268/161/0722091640u.jpg
Everything works fine except the car seems to go into a limp mode when I'm WOT or close to it. If I keep my throttle only partially open, the car will boost the 5.5 psi with low 12 a/f's. But as soon as I go WOT (even before boost is built), the car seems to go into a limp mode, not the actual ecu limp mode with a CEL, but my A/F ratio gets pegged at 10 and the car is extremely sluggish.
At first I thought it was because of the map I was using was for the Z6 and it was just dumping fuel for the vtec engagement, but that would only happen in the upper RPMs. With this problem, I could be going 3000rpm, peg the throttle, and a/f will instantly go to 10.
It is wired up correctly (followed the wiring chart here, and double checked it with the emanage manual). I don't get any error codes, rotor settings are 28b and jumpers are 2-3, 2-3, 1-2, open, open, open, 1-2.
Any help would be appreciated.
1 - 1 of 1 Posts
