1 - 6 of 6 Posts
it can, but the things are a bit complicated .. Not because of the boost, but because of the timing, which would not be an issue if you use EManage Ultimate with bigger injectors ..
EManage blue can't lean bigger injectors without messing with the MAP signal, and that's what sucks about it.
1 - 6 of 6 Posts
