1 - 10 of 10 Posts
We started the project of a D17A2 conversion to OBD1 and keep the individual coils functioning , here the progress...
The patient is an EM2 D17A2
We started working the cam so it can run the distributor.
EGR Removal:
Then the instalation of the distributor because we need TDC CKP and CYP signals , plus we need to do some mods to the distributor so it can fit because of the water pipes.
We still have to manage to put a distributor cover and make that small water hose a little longer and out of the way
· BATSLOMAN GIVES NO FUCKS.
I told you, post the link with a space somewhere in it and I will come back and edit it. reading pwns you
Discussion Starter · #7 · (Edited)
Why not just run Kpro?
Way too expensive compared to the fact that you can do this mods and just make it work with OBD1 and tune it . but that is not the whole story , remember that in the middle of this project a coil controller was developed by us that could work with all OBD1 for coil on plug and is not an expensive solution. :)
Nice work so far!
I'm actually very interested in how this project ends up. I'd love to be able to (relatively) easily run a chipped p28 on my D17.
Based on what you have completed so far, could you simply run a full distributor ignition? If you didn't want to keep COP
Nice work so far!
Yes , but the whole idea is to keep it with the COP . Im actually merging the ECU with the controller and installing the circuit inside the ECU . I will post pics as soon as I finish the experiment :)
1 - 10 of 10 Posts
