1 - 3 of 3 Posts
ok so I did an engine swap on my 98 civic dx and I put in a d15z1 motor in which is an older motor from the car I changed the computer to obd1 p28 with a jumper harness I am cranking the car it sounds like it want to start but it don't want to is there anything that I should change electrical wise? like distributor and what not.?
so you have odb1 engine with odb2 wiring and an obd1 ecu with jumper? that may be a problem...
1 - 3 of 3 Posts
