C
finally did my ek front end conversion on my eg civic coupe...
overall is really clean and nice, a lot of envyous people, the motor of an eg but with an ek look!
took a little over 5 hours of labor...wasn't too bad to do, aint as hard as i though...
too tired right now to explain how to do it, want to post pics...but my digi cam is acting up...
C
i HEARD plug and play is possible...i eyeballed it once...seems like some customizing and it'll be possible, not sure
but what i did was i changed the core support, then after that it was pretty much plug and play.
the 96 hood gotta be hammered down a little, but with me, i cut it since my hood was fiberglass...if you try it, you'll know what i mean, aint a biggie
i used the stock 92-95 civic fender and just cut it the same shape as the 96 headlights
you dont HAVE to weld...like the core support i weld just to reinforce, but there are a few bolts that could hold it up...i wouldn't recommend it, but do-a-ble without welding
but yea, one can do the conversion without welding...cutting and drilling is involved though..but it can be done at home for DIYers
C
alright, i have a little time right now so i'll explain how to do the conversion to any who are interested.
Parts you need:
96 hood
96 headlights
96 bumper
96 core support (70 bucks brand new)
first off, take the whole front end off the eg civic (hood, fenders, headlights, bumper, corner lights)
keep all the bolts and nuts
then drill out the spot welds for the core support, they are the little dents
once almost all of them are removed, take off the a/c and radiator, you dont have to disconnect them or drain them, what i did was had a few buddies hold them up for me, not heavy at all
once the core support is off (all spot welds drilled out, and some tapping with a malet/hammer) start spot welding the new core support
the new core support should line up pretty nicely, there are a few bolts (i think 2 or 4) that will hold up the core support, after these bolts are in place, the core support should be able to hold up, and it's a way to reasure that the core support is lined up properly
here's where there's a decision, spot weld the core support or not, i spot welded them, had a shop do it for me, because i dont have a welder, would highly recommend spot welding the core support
after that the bumper and headlights go bolt right on
the hood is a bolt on, except it wont close...because the end of the hood (next to the windshield) is hitting the firewall...this can be easily fixed with a hammer/mallet, just hammeredf that shit in or you can cut, which i did because i have a fiberglass hood, i'm talking about the underside of the hood
after that is done, the hood should fit
the fenders, what i heard was that you need to cut and weld the eg and the ek fenders...but i just cut the eg fenders to fit, cut it to the shape of the 96 headlights
i measured where to cut by closing the hood and marking where the cut should start on the fender (this is without the headlights on)
then i traced the shape of the 96 fenders and drew it on my eg fender starting at where the cut should be, then i cut the fender along the marks/drawing
after that just put everything back pretty much
dont forget to take the hood latch off the old core support
if this conversion made you broke, start selling your old parts
i think i covered everything...any questions just ask
C
pics!!!
got my digi cam/camcoder back and now i can post pics!
heres the conversion, i have a fiberglass hood so i made custom DIY hoodpins because i've heard stories of fiberglass and carbon fiber hoods flying off in the freeway!
and i know, i need to drop my car and get a red bumper...
ridin on rotas
well I think it looks good. good job. just get it painted. you should have gone with the 99-00 si front and it would have come out 10 times better. but props for the work.
