1 - 14 of 14 Posts
I have a 1996 EJ8, the people I bought it from put a D16Y7 in there and left the P2P-A31 ecu it boggs at 55k rpm..
I would like to know should I swap to a y8 head (car has all vtec plugs still) or change to a non vtec ecu...
I want to build it up maybe 175-200hp. What is my best option..
Integra DB9
Well, you won't get any normal D series to rev past 55k rpm!
1 thread is all that's needed. not sure why you made 2 threads in 2 different forums.
swap the head and be done.
find a 96-98 d16y8 head and install it to solve all your problems, and gain a bit of compression while you are at it.
Discussion Starter · #5 ·
Thanks for the info.. I can go pull a head on Saturday..
Do I need to anything to the block? Or just bold the y8 head?
Sent from my XT1635-01 using Tapatalk
Discussion Starter · #7 ·
While your at it, can you paste the results....
(People like you is why I don't ask for assistance)
and people like you is the EXACT reason Im an asshole.
the circle of life is viscous. wear a helmet.
Discussion Starter · #10 ·
An I was just asking for advice, not trying to fuck up my ride and money is too tight for a motor swap
Knock sensor is related to 1999-2000 civic d16y8's
Id suggest training your google-fu, its awesome how much information is out there regarding honda's.
The shitty part, is that they are so cheap EVERYTHING from the most basic stuff to the most advanced stuff has a lot of conflicting information.
In other news, search for "d16y7 oil jet" as a push in the right direction regarding your head swap
1 - 14 of 14 Posts
