1 - 20 of 21 Posts
CR-Vtakin
your mom
that you are low on oil and probably about to blow your motor. it is reading that you are not getting signifigant oil pressure. either you have low oil or your pump is not pumping the correct psi.
it means you will be replacing bearings today...or somtime this month.
duh
Maybe the sensor is bad.
I had to replace the one in my wifes Lancer.
She told me it was flickering on and off the whole way home one day.
I was like:shock:
It wasn't knocking and there was oil in it.
So I put a new sensor in and fixed, no more oil light.
my Skateboard
My light flickerd a couple times during hard lefts, turns out I had a bad leak and almost all my oil was gone.
smh. fix the oil leaks homie, or does the engine consume the oil? check your PCV valve make sure its not clogged.
Well?
my del sol would do that and guess what happened...
ej2
Discussion Starter #16
The good news is you probably don't have to mess with the drain plug. Change the filter and top it off.
Ding-Ding-Ding-Ding..
I had very little oil..
Time for a oil change.
thanks to all of the pessimist...
no spun bearing..
Or fucked up rods here:bigok:
no spun bearing..
that you know of yet.
I survived code 9
1998 Honda Civic DX
Buddy you need to fix the leak...
What caused it to be leaking in the first place? IT shouldn't be low...
One time I took a hard ass turn in my escort and the oil light came on hahaha. I checked it RIGHT after that and it was fine.
1 - 20 of 21 Posts
