Hey what's up, I have an ej1 with an b18b swap, it's 100% stock, my motor leaks oil from the driver side only when I turn off my car, I cleaned up the oil pan and area around it, it seem to come out the diver side corner from the oil pan (side closer to front of the car), well I did the oil pan gasket and it still leaks oil but it seems the oil comes from the crank shaft pulley.. Any ideas?? Is there a gasket there??
front main seal/oil pump
Sloppy Jalopy
should be ok ,if you are careful and follow the fsm there will be minimal chance of venting a vavle or two
