1 - 7 of 7 Posts
EG hatchback
i got oem D15z1 EG VX motor ready to be swapped out with a built d16z6 vitara motor.
The EG harness is oem VX with 5 wire O2 sensor in it and i assume the p28 ecu is only 4 wire ECU p28. manual.
is it necessary that i have to convert the 5 to the 4 wire o2 sensor?
if its needed how do i need to do the wire swap. i already have my 5 wire o2 sensor.
and how about the other VX components do i have to remove them from the harness? the p28 vtec don't have that egr things? can i just leave them out and just do the 5 to 4 wire only?
whats need t orun the z6 motor.
does anybody know if i have to convert this. pls let me know..
thanks...
Yes you need to convert it. The p28 ecu can't read the 5 wire o2. You need the 4 wire o2 sensor,the female plug from the harness for the 4 wire o2 sensor.
Can you post pics of the plug on the engine harness for the 5 wire o2 sensor?
EG hatchback
i will get a post as soon as i borrow a friends phone.
How will i do the conversion? do i have to splice the ecu harness?
i got a used plug from a used honda that had vtec i just need to make my own wires to connect to the ecu. the problem is that i don't know what wire i have to put to into the ECU harness?
also do i need to cut off any other wires in the harness?
like egr etc? or do i just do the 4 wire conversion.
EG hatchback
ok i finally got the pic. the harness connector is actually 7 wires from the engine harness plug. the 02 sensor harness connector side is online 5 wires? wtf??
i got the pic of the harness, but not the 5 wire o2 sensor. i still have to find it i think i threw it away?
heres the pic
Trust me when i say source out a virgin z6 wire harness....it will plug into your chasis harness and then its just plug and play. The only wires that may need to be ran aare your vtec wires
EG hatchback
ive already used the old harness i couldn/'t get a ex one. i just extended some wires. like sensors near the dizzy. area.
i got a ry wire sensor conversion kit.
i followed wiring. i looked the wiring color the A side of the pin is the same but the D plug harness colors where different.
i looked the schematic on the vx harness and EX harness schematic diagram the wires of the vx to ex where different colors o2 sensor but i still just used the position they told me to de pin and re pin with the supplied wire.
will that still work?
Start it up and check for any codes.
6yrs ago I swapped a z6 with its harness into my vx with original chassis harness. 1 code came up everytime I would downshift for the 02 sensor. I chased the wires and found 1 wire did not go all the way to the ecu. It was on the extra plug that was not used. I de-pinned and repined to another plug. Never had the same problem again after that.
Maybe you have to do something similar to what I did but with the original harness on the motor.
1 - 7 of 7 Posts
