21 - 40 of 48 Posts
Discussion Starter · #37 ·
jdm d15b vtec head - 45,000 miles-ish complete w/ valve cover, never taken apart (insides still clean!!)
y8 intake manifold
- noob port matched to b18b tb... (pics coming soon)
b18b throttle body
- untouched, w/ 75,000 miles (came off of a friends da integra)
jdm d15b block
- rings on the 2nd cylinder are bad. it was boosted with 10psi. oil pan is jb tapped for turbo. pistons are nice. i have measured the cylinders yet, but ill update when i get a chance.
ex/si transmission
, slight grind into 3rd when you slam it, otherwise really nice. i was told it had 60,000 miles on it when i bought it (from a yard). and i put like 10,000 on it.
JDM D15B Intake Manifold w/tb and fuel rail......................................................$45 (no sensors)
JDM D15B Upper Exhaust Manifold.....................................................................$25
P28 Socketed, blank chip, *open-loop only *REPAIRABLE* contact me.........................................................$80
Hondalog Datalogger........................................................................................$30
Complete EG Suspension...................................................................................$200
Tein springs on Dropzone struts... 7000 miles
comes assembled with oem parts
***Turbo***
DSM 16g. no shaft play. there was oil in the j-pipe when i took it off.
probably needs a rebuild...update: my motor was spitting oil after the turbo was taken off. turbo may be good!............$70
DSM o2 housing.........................................................................................................$25
DSM J-Pipe.............................................................................................................$15
HF Exhuast Manifold
(has the 3 on the 4th runner) no cracks......................................................................$45
2.25 Downpipe for Hf mani, dsm o2 housing, in an eg. has a z6 flange...................................$100!!!
Front Mount intercooler (core=20x6.5x2.5)....................................................................$100
16g wastegate 10-11 psi................................................................................................................$offer
14b wastegate 7-8 psi..................................................................................................................$offer
Stealth Mode Water Lines.............................................................................................$20
Stealth Mode Oil Tap...........................................................................................$20
Stealth Mode Oil Tap -- http://tunertoys.zoovy.com/product/OTODK
21 - 40 of 48 Posts
