EG Hatch High Compression Build
6214 Views 74 Replies 7 Participants Last post by  Cheetoh
9
Decided to document my 93 Civic DX Hatch Restoration/High Compression build. I picked up this Auto Hatch with a straight body and minimal rust. Decided to start off with the suspension first before I send it off to paint. Still on the fence whether I want to repaint the engine bay. Here are some photos of how she currently sits.
136225
136227
136228
136226
Plan is to do an ITR Front and Rear brake upgrade with hardrace bushings throughout. Picked up an Integra rear trailing arm set with e-brake lines.
136230
136229
These were a pain to break down. The hub got stuck the rusted spindle.I ended up breaking a flathead trying to pry the hub off. Had to use/modify a valve compression tool to get the remainder of the hub out.
136232
Decided to buy a press from harbor freight to get the rear trailing arms out since those where rusted in there pretty good. Going to use the remnants to press in the new trailing arms and front bearings as they seem to be just the right size.Going to be running Timken bearings front and rear.
136233
Here is the finished product. Ended up putting two coats of Rustoleum black enamel. Also busted out my buffing wheel and polished the rust off the spindles. Now just waiting on more brake parts to come in.
Reactions: 3
21 - 40 of 75 Posts
That's heading to be an awsum ride!
Whats the drive train going to be..
Still putting together the parts but for sure High compression D16Z6. If I ever sell my K series supercharger, I can get her a rebuilt LSD transmission. I am on the fence still between 12 to 1 and 13 to 1 e85 build.
If you use a 3 - 5 pound steel mallet, a lot of those suspension parts are cake.
3 tricks I use on the ones that give me trouble are -
Heat
Brake fluid (it penetrates way better than WD-40)..
The freezer (for anything I'm putting in).
If you use a little heat, you can bang something like a ball joint out in about 10 seconds.
Put the new ball joint in the freezer for about 30 - 60 minutes before you put it in. Throw a little grease on the sides and it will go in so well, you will think it's too loose. Once it warms back up, it will expand to the proper size.
Heat and brake fluid together work excellent to penetrate stuff. A little heat , add brake fluid and repeat. I just throw some cardboard down to catch the excess. This also works for stuck adjustable coilovers. But I like to keep the heat down to a minimum on them. Even ones that I throught would never let go eventually do. Flash heat, brake fluid, repeat.
I had my passenger, lower ball joint snap on my Del Sol recently with my kid in it. It literally snapped in half. That sucked. Ripped the passenger axle out and did all kinds of damage. Luckily, I have garage full of 88-00 parts galore and two donor Sols out back. I got the whole repair done in an afternoon...including removing the parts from other cars.
Well not the best of updates. My paint & body guy ended up being a piece of shit who made promises but never actually finished the car. Finally was able to track him down after he went MIA for a couple months and get the car and the majority of my parts back in my possession. I am still trying to get all of my missing glass and I think I am missing the front windshield trim. I also need to replace one of the new ebay rear tail lights since they are broken due to his shitty care.
This is how I got the car back.
Wheel Tire Car Vehicle Hood
Tire Wheel Vehicle Car Automotive tire
Automotive parking light Hood Automotive tire Automotive lighting Automotive tail & brake light
Luckily one of my friends has a welder and knows how to weld body panels. We were able to get these all lined up and tacked in but we ran out of gas for the welder. Plan is to fill in the gaps and the trim holes sometime this month when he gets some free time. On the plus side, it was cool to spend time with him since we rarely get to hang out.
Tire Wheel Vehicle Car Automotive lighting
I spent the weekend working on the nasty old sound deadener. I used up over 20 lbs of dry ice and broke a harbor freight needle gun trying to get this stuff off. Plan to hit it up with goo gone and sand everything down to get ready for paint.
Fluid Automotive exterior Cuisine Gas Motor vehicle
Auto part Art Space Motor vehicle Event
My plan is to get a road race style cage and do a half gut on the interior. Then rattle can paint match and 2K clear.
Reactions: 2
that sucks. but at least you got most of it back.
Gave you a like, but dont like what happened. That shit sucks. Glad you got back what you did.
Was the dude trying to steal the car from a "hopefully he forgets about the car while i drop off the grid" perspective?
Definitely seems sketchy as f.
No, he just had other jobs that paid more so he kept working on those is my guess. He changed his contact info several times and wouldn't answer calls or texts. I had to threaten to report the car stolen and then he finally gave it up. He moved shops and come to find out he owed money at the old shop and left my car there. They wouldn't let him remove the car until he paid up. I don't know the full truth, the guy always had stories and new timetables. I am hoping to get my glass back since that will probably cost me a couple hundred. I might do the body work myself at this point too.
Spent a productive day cleaning out and disassembling the car some more. I was able to get the rest of the gunk out and pull the carpet and seatbelts. The carpet got vacuumed, powerwashed, then cleaned. Even though this carpet is in pretty good shape, I will probably dye it again.
Automotive tire Motor vehicle Hood Bumper Road surface
Sleeve Road surface Asphalt Grey Tar
Tire Car Vehicle Hood Motor vehicle
Reactions: 2
The carpet turned out well after the good cleaning. I decided to use the Duplicolor Flat Black Vynil and Fabric spray paint on it which really came out well. I used up an entire can for almost 2 full coats. Would have liked to do another pass but I ran out. I brushed the carpet in between coats to try to get different angles of the carpet.
Automotive tire Bumper Automotive exterior Gas Tints and shades
Bag Grey Personal protective equipment Denim Font
Reactions: 4
Messed around with my oven last night and cerakoted a couple parts. I ended up doing this front sway bar but quite didn't like the finish since it was more of mat color. I ended up spraying some gloss black over it. It should still be pretty durable since the base is baked on. I also did high temp Piston coat on my 12:1 Arias forged pistons which came out great.
Paint Wood Rectangle Art Gas
Street light Road surface Grey Asphalt Material property
Product Font Material property Body jewelry Circle
Reactions: 2
My friend stopped by and welded up the rest of the panels and we filled in the trim holes and some drill holes in the interior. All that is left is for me to grind the welds down. I have been dealing with hand pain after the vaccine and I hope its not early arthritis. As it seems now, I don't think I will be able to do the body work myself. The car has an appointment with a fabricator in early July to get a half cage put in. After that I will be looking at getting the car painted again. Still need to order up some missing seals and have to find the glass.
Tire Vehicle Car Wheel Hood
Reactions: 3
Just a small update. Got a surprise yesterday. The painter called me up and said he had my glass and my front windshield trim. I was seriously not expecting to get them back and had already started to source replacements for the glass. The car went off to the welder to get the half cage created. I picked up a tig welder and plan to learn to tig so that I can put together the custom exhaust I have.
Reactions: 3
Lucky! Dude, i bet those side glass replacements were expensive and hard to find!
Yeah, glad the guy did something right for a change. Easily 500 in parts between the glass and trim pieces. I forgot that he also had the door trim too. The part that normally goes silver over time.
Ha! Im re-doing my black turned silver strips as well lol
Removed all the black, and will reshoot them with black bed liner. New clips were only a couple bucks.
Yeah, I purchased these before getting my own cerakote oven. I can spray them to oem look now. Even though it is more expensive, I am glad I am able to restore some parts back to factory oem. This car probably wont see much daylight once it is complete. I plan to race it at our local track and use it as advertising at car shows for my side hustle.
Reactions: 2
4
The welder knocked out the cage in record pace. I quite didn't like the open space under the harness bar so I had him add on some more bracing. I think the over all looks way better and should be safer. I wish I could afford the full 10 point cage but going to stick to the half. The welder built it in a way that we could add on to the full 10 point in the future. I was really surprised that he ended tiging most of the cage. The cage is made out of 1 5/8 .083 Chromoly which should cover me for most all racing classes as long as the car stays under 2600 pounds. I feel kind of bad that I will be painting over his welds. Right now I am leaning on the Roth Paint Rattle Bomb Blue or their Nightshade as a nod to my lowrider childhood dreams.
Vehicle Motor vehicle Hood Automotive design Bumper
Motor vehicle Hood Automotive tire Automotive design Car
Car Vehicle Automotive tire Motor vehicle Hood
Automotive tire Motor vehicle Rim Wood Alloy wheel
Reactions: 2
Not much progress this week. Still trying to find a painter pretty much. Don't want to really pay shop prices as I am not really looking for that level of a paint job. I got some flap disks and was able to grind down all of the welds. This was way easier than just using a grinding stone type wheel.
Wood Grey Fender Vehicle door Automotive tire
Car Tire Vehicle Wheel Hood
Hood Automotive lighting Motor vehicle Automotive tire Bumper
Reactions: 2
5
Big progress on hatch. Got it back from paint and it came out great. Still need to do some wetsanding to get some orange peel in certain spots but it looks great. Tackled the brakes and suspension over the weekend with a friend. Hit a couple of snags. I was missing the front brake hardlines. I was able to source the passenger but not driver. Hit the junkyard up hard but my wrench kept stripping the nuts. Just couldn't get any off on the 3 cars that where at the junker. Will probably have to try again to source one locally. The rear toe arms were fused to the nuts which was a pain. Had to pick up a saw saw to cut out the bolts. Also had to cut holes to put the retaining nut back in place. Not sure if I will get this covered up after install or if will just throw undercoating in the new exposed area. I guess this is a common problem though. We had some difficulties getting the lower control arm bolt to line up on the Honed Development kit. Hoping to have all of the brakes done in the next couple of weeks. Once that is done, I need to tackle the harnesses and the cluster conversion. I did pick up a built Whoopdeedoo LSD transmisison on the forum. Still waiting on the engine builder. I hope to have her up and running by Spring.
Car Tire Vehicle Wheel Motor vehicle
Tire Wheel Motor vehicle Automotive lighting Automotive tire
Wheel Automotive tire Locking hubs Motor vehicle Vehicle brake
Grey Wood Tool Electric blue Metal
Gas Bicycle part Auto part Pipe Wire
So sick! Looks amazing! What are your goals again for this car?
Thanks! I want to do some road racing and be able to drive it from time to time. Hit up some shows to do advertising for my side business.
Reactions: 2
21 - 40 of 75 Posts
