Tired of ridiculously high prices on ebay for your CRX climate controls? Have no fear! I have seen the post on the accord controls but those knobs tend to break and that seemed like way too much work. Instead, I went with 92-95 EG climate controls with the sliders. Surprisingly this was very simple to do.
First we need 2 simple parts and both can be had on ebay. I got lucky and found both the harness AND the control unit for 35 bucks shipped.
EG harness
At this point go ahead and cut the green plug off the EG harness and prep it for wiring. I used butts but this is not a debate of what to use so before anyone says anything....shoosh! You can use butt connectors, tape it, solder it and tape, crimp caps, wire nuts I don't care whatever you think works.
This next part will be edited for wire colors tomorrow. Basically they are all the same except 2. A tan wire on the crx harness goes to the yellow wire of the eg harness and a green/white on the crx goes to the green/yellow of the eg. The rest are all the same and yes, I checked them.
No cutting or spicing of the fan speed control is needed. This is a DIRECT plug in.
One simple mod to the EG control needs to be made for the cable mount. Here you can see where I cut off the mount.
And this is where it gets placed. I had to drill one hole in the unit for the zip tie. One zip tie should do the trick. No modifications to the cables or cable ends need to be made.
EG harness
