So i just need some advice. My 94 ej1 has an a/c issue where the compressor only turns on when you either press the a/c button with force and hold it OR when you move the wire with the green plug behind the climate control box. either way it is shorting somewhere. should i just buy another box?
Sloppy Jalopy
Doesn't sound like it's shorting, sounds like the switch contacts aren't closing the circuit properly.
If you feel like pulling apart the switch and cleaning / bending the copper contacts, you could try that first before replacing it.
that sounds like work ...
but yeah do what he said.or just change out the switch .
if you want to make sure the switch is the culprit just jump the wires at the switch..
oh it is a b**** to get out, i still haven’t figured out how to get the green plug out of the dead center of it, but i’ve been thinking about scrapping the box all together.
also might i add that sometimes when i get it on i can feel the compressor kick on and off CONSTANTLY when driving, before it finally just shuts off. even when i came to a stop at my job the other day it fluctuated until i mashed the button with my thumb, then did it later on my lunch until i moved the wires on the plug (after scrapping my dash) and it would only kick on if i sat there and held the plug/ pressed the button. idk how that messes up like THAT but oh well.
