I drive a 91 std hatch with a 4speed, if I get lets say a 90-91 si tranny will I have to get 5speed hubs from a ef or can I get some from a eg?
you sure? I was thinking the HF and STD shared the same smaller hubs.Your hubs should be fine. The only EF you need to swap the hubs on to run an SI tranny is the HF.
:werd:as long as you use your stock axles, you can keep your stock hubs
