81 - 99 of 99 Posts
89 EF 4wd sedan
Discussion Starter · #81 ·
youre not going to pressure test the tank?
I've got a vacuum pump that i could throw on it which would make sealing it up easier than a positive pressure. I was a bit worried about the tank collapsing though. Not really sure what kind of pressure is enough to check, but not enough to accidentally collapse the tank.
Never used one personally, but pretty sure in North America they are called "cock" rings.
I cut a few spares, hmu.
pull enough to see if it holds lol. hate for you to do all this work, throw it in, and waste 20$ in fuel on your driveway lol
Reactions: drtalon123
Sloppy Jalopy
Couldn't fucking help myself lol :)
thought I missed something had to go back over his posts. Jeez making me read more than I have to ..
It should pretty easily hold 10 psi, or 10 inhg vacuum. The CA evap test subjects these tanks to those pressures/vacuums regularly. Had it not been cleaned, cut, then welded I'd recommend an inert gas like nitrogen or CO2 to pressurize with and a brushless vacuum pump to pull vacuum with, but you should be fine.
89 EF 4wd sedan
Discussion Starter · #87 · (Edited)
I didn't know that, thanks! I had a google, and it looks like they pressurise to 10inH20 not inhg, which is actually 0.5psi.
Maybe it's only at the smog ref they take it to those extremes? I'll have to ask, I've never paid attention at the actual smog shop, hes one of the 3 people around I dont have to watch like a hawk to make sure something doesn't go stupid.
89 EF 4wd sedan
Discussion Starter · #89 ·
Decided to just yolo and give it a go. Crazy how much the tank expands under pretty low pressure so i didn't push it that much, but i didn't really need to. All the welds held up fine, and the compression height of the pump gasket is perfect with the new stud ring. Lucky i tested the tank though, the vent port had somehow become blocked (line that goes to the very top of the tank to vent air when you're filling it up), hooked up my gun to it at 40psi and it was completely blocked. Cranked the pressure to 90 psi and blew out whatever was blocking it. Probably the same fkn spider that was blocking my fuel lines in the track POS if anyone remembers that.
89 EF 4wd sedan
Discussion Starter · #93 ·
So many shitty jobs in this EFI swap, Saturday i spent making up a return line. I ended up using the Concerto line and bending it to contour the rear half of the car. From:
to
and
to
It also took me longer than i'd admit to figure out the routing for the evap/emissions lines. Because it was a combination of carb/EFI it took a solid hands on hips staring session to figure out what went where. Hopefully this pic helps anyone else doing this swap, the two ports with caps on them are welded internally (not just capped at the port):
Did you use a knock out bit to roll the edge? Or is that just the angle the picture is at?
Formerly weebeastie
Hahaha! So glad to see that I'm not the only one on here who will occasionally spend way too much time making something be as perfect as I want it to be, but then other times I just say, too heck with it and send it. Too many little things that need doing and not enough hours in the day to do them. All the fuel tank work looks great though!
89 EF 4wd sedan
Discussion Starter · #98 ·
After i cut the hole i used a socket and a ball peen hammer (ghetto dimple die) to roll the edge. The grommet i used is the wire harness grommet right where the dash harness goes through the dash near the clocks connector, so the gap between the inner/outer flangers was about 2mm (the thickness of the plastic section of the dash). The sheet steel thickness was about half that so i needed to roll the edge to increase its thickness so the grommet would sit snug and seal correctly.
Chars! Yeah this build is somewhere between my other two builds, im super fussy with the EF, while the track pos is just fast and loose.
When things get too fast and loose though @slo_eg8 guilts me into doing things properly.
81 - 99 of 99 Posts
