1 - 7 of 7 Posts
W
You’ll need to run the blue wire (or whichever color is from the plug) to pin D6, and then run the black ground wire from the plug to anywhere on the motor. You then need to run the green wire from the VTEC solenoid to pin A4.
T
thanks men for the help hopefully i can get it to work
W
no problem post back if you have trouble
W
DeeSeriesTurbo1969 said:
ok when you say the blue wire which one is that?
i said it, blue wire or whatever color is coming from the plug.
1 - 7 of 7 Posts
